counter current, DPM
Hi, i'm working on a problem with counter current twophase flow in a tube ( using water vapor and water liquid droplets).
i'm using DPM. i want to desuperheat the superheated water vapor with spraying water liquid. water liquid enters from outlet and water vapor enters from inlet. how can i model counter current in DPM? & how can i fix the "turbulent viscosity limited" problem?? |
http://www.engr.uconn.edu/~barbertj/...2012/tut17.pdf |
