multiphase
Hello everyone
i have run multiphase case in the fluent and the calculation has been finish. and save the results. but later on when I tried to open the result again it shows this message: Setting Post Processing and Surfaces information ... Error: lvectorref: arg(2) out of range Error Object: 128 is there anyone can help me to solve this problem |
Are you opening the results file on the same computer, and Fluent version?
Hello, yes I opend it in the same computer
Does saving and opening non-multiphase simulations work fine? Are you saving Fluent, and then opening Fluent via Workbench using the 'Solution' cell, or with .cas/.dat files?
Fluent sometimes asks if you'd like to save changes to a mesh or otherwise. Perhaps if you're trying to open the data files with another case then you'd expect errors. |
