April 8, 2015, 05:51 |
vof condensation
SVB VIVEKANAND
Rep Power: 11 |
hello everyone
i am new to ansys and hav little experience of it. i just want to simulate a condensation problem in microchannel using fluent. the details are given at the bottom. i really want a guidance from any of you for this purpose. i tried the problem but failed few times and also dont hav any idea of my failure. please help me. the details of my problem are:- computational domain: rectangular microchannel of 100micrometer hydraulic diameter and length 0.03m working fluid is R134a, operating condition is 1MPa. mass flow inlet(492.2kg/m2s), pressure outlet and heat flux of 400KW/m2 at walls with no conduction. fluid enters in the form of superheated vapour(degree of superheat 10K) |
April 9, 2015, 04:40 |
Rep Power: 13 |
What would you understand if i posted what you posted above? Would you understand my problem at all? I think not.
Elaborate more please. |
April 12, 2015, 05:21 |
sorry for not explaining the problem clearly.
SVB VIVEKANAND
Rep Power: 11 |
Thank you hwet for your reply.
Can you please tell me you emai id so that i can share a journal paper which i want to reproduce to gain confidence in me. the paper describes the problem totally and you will surely help me out then. as the paper is of larger size so i am unable to share it here, so kindly provide me your email id please Last edited by vivekanand; April 12, 2015 at 05:23. Reason: typing mistake |
April 14, 2015, 11:35 |
SVB VIVEKANAND
Rep Power: 11 |
hello anybody here!!!!
come on i no some of u can definitely help me out. please reply....n if the problem is not clear or not well explained by me then please share email id so that i can send the paper describing the entire problem(paper's size is more so has to be mailed.) |
Condensation UDF in VOF | foolstop | Fluent UDF and Scheme Programming | 6 | June 23, 2013 21:59 |
VOF - NO Condensation !!!!. | JSM | FLUENT | 2 | May 12, 2012 09:08 |
VOF condensation udf | foolstop | Fluent UDF and Scheme Programming | 0 | May 8, 2012 09:15 |
evaporation and condensation in the VOF model | Glev | FLUENT | 0 | December 24, 2004 04:55 |
Using UDF in VOF model for Condensation | Crystal | FLUENT | 6 | September 26, 2004 18:08 |
