Outlet BC for subcritical open channel water flow |
April 18, 2015, 04:57 |
Rep Power: 11 |
Dear all.
I am simulating an open channel flow (multiphase VOF), in particular a subcritical flow, so I need a specific outlet (or downstream) BC, in particular the water depth. If I do a transient (unsteady) simulation, is it right to impose this downstream BC? Because, let's you imagine the phisics of the transient time; the channel begins to be filled by water from the inlet; if this water has not still reaches the outlet, how the flow can "understand" the downstream water depth BC that I imposed? Thus, is it right to impose this BC for an unsteady simulation? Thank you |
boundary condition, multiphase, open channel flow, subcritical flow, vof |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
reverse flow occur while activating open channel flow boundary? | mariam.sara | Fluent Multiphase | 7 | April 26, 2015 07:24 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 14, 2010 23:54 |
pressure outlet (open channel flow) | Willem Brantegem | FLUENT | 2 | April 4, 2007 02:40 |
pressure outlet (open channel flow) | Willem Brantegem | Main CFD Forum | 0 | April 3, 2007 09:39 |
