Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
2- phase flow with VOF
Old   August 18, 2015, 01:21
Default 2- phase flow with VOF
minu
minu is on a distinguished road
Hi there...
i want to simulate formation of bubbles (Taylor bubbles) in a microchannel with 2 inlets and 1 outlet. one of inlet is the entrance of air and others are entrances of water. i do these steps but i cant get the answer. after running it seems that air and water do not mix at all. any one can help me????
i am so grateful for any clue.
these are my steps:
define-models-solver-pressure based, implicit
define- multiphase-vof-explicit,co number=.25
define material
define phase-primary phase: water,secondary:air-interaction: check adhsion,surface tention=.072
BC
inlet1(which is inlet of gas)-switch mixture-velocity magnitud=gas velocity-switch phase 2-VF=1
inlet 2 and 3 just like above with liquid velocity and VF=0
all walls-switch mixture-contact angle=50
solve-control solution
solution intialization-with all initial values zero-init
adopt-region-select the inlet of air-mark
solve -patch-phase2(air)-VF=1-select adopt region-patch
iterate with time step=1e-8
minu is offline   Reply With Quote
Old   August 19, 2015, 07:24
minu
no one can help me???/
i need your help friends...
Old   August 19, 2015, 09:28
Default surface tension
Parisa is on a distinguished road
Well I don't really know if my answer is relevant, but have you checked your surface tension value? It is under phase interactions.
//Parisa
Parisa is offline   Reply With Quote
VOF - slug flow modeling Nick FLUENT 8 March 24, 2014 11:35
two phase flow using vof method saketh9187 FLUENT 0 January 10, 2013 05:50
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 19:01
How to simulate three-phase flow in VOF? adam14qin FLUENT 0 July 28, 2012 04:02
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
