open channel inizialization with water surface parallel to the bed |
October 9, 2015, 16:22 |
Rep Power: 11 |
Dear all,
I would like to simulate an open channel flow, but I have a problem in the initialization. As initial condition I would like to have a water profile parallel to the bed, thus I impose a free surface depth at the inlet and at the outlet. I use the FLAT initialization for open channel flow, but the free surface which is generated is horizontal, and not parallel to the bed. I have tried to use both hybrid and standard initialization, starting both from the inlet and from the outlet, and also selecting "all zones". Do you have advices? Thank you |
initialization, inlet, open channel flow, water depth, water surface profile |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
free surface level set in in Open Channel Wave BC | hamidcfd | Fluent Multiphase | 2 | December 12, 2016 12:08 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
