November 1, 2015, 12:28 |
Convergence problem on the energy equation
goku
Rep Power: 10 |
I am working on HVAC.A 3d room with 3 inlet window and 3 outlet window in opposite direction.Inlet velocity is 0.1m/s. outlet is pressure bounday condition.
The turbulence model used is K EPSILON. Heat flux from floor is 10w/m2. when i solve the (flow & turbulence )and energy equation separately the solution is converged.But when i solve the equation together the energy equation is not converging. It shows the error Divergence detected in the AMG solver: temperature. Error object :#f. Pressure based solver, gravity is switched off.. |
Natural convection energy convergence problem | sanooj | FLUENT | 5 | October 29, 2015 07:23 |
Convergence problem with continuity equation in microchannels.. | vikasy123 | FLUENT | 2 | October 14, 2015 02:33 |
Convergence problem in energy equation | majidtaleby | FLUENT | 0 | June 22, 2010 16:32 |
Viscosity and the Energy Equation | Rich | Main CFD Forum | 0 | December 16, 2009 14:01 |
Need help:about energy equation in CFX | Stein | CFX | 4 | July 2, 2009 22:31 |
