December 30, 2016, 03:41 |
particle trap visualization
Rep Power: 9 |
i simulate multiphase flow in fluent and i work on DPM. there is a problem i have searched a lot for it in the net and i have tested every option in fluent but found nothing. if anyone has any information about this, i would appreciate to share it:
how can we visualize the trapped particles on any of the domain walls. my model includes a bend and particles get trapped on the bend and the straight pipe after the bend. i want to see where the particles are trapped. it is very important to me. i appreciate any answer. |
January 1, 2017, 12:08 |
Rep Power: 9 |
any idea????!!!!!!!
January 9, 2017, 18:18 |
Rep Power: 13 |
if it is in steady state you can just go to particle tracks in the visualization options and track the particles. if it is unsteady you can write a particle data file and read it in cfd post to display the tracks. see the tutorials in the fluent tutorial guide, this should be covered as it is fairly basic and used a lot.
January 11, 2017, 15:26 |
Rep Power: 9 |
actually i don't want the trajectories of particles. i only want to depict the trapped points of particles on the walls.
February 2, 2017, 11:57 |
same problem
kaveh
Rep Power: 9 |
actually I have the same problem and I didn't find the answer. but I think this problem don't have steady state part which means you should run the problem without particle then write this and activate the particle track. but I don't know how too find the location of particles
February 2, 2017, 17:28 |
Rep Power: 13 |
If you guys want to visualize the particles actually stuck to the wall you might have to use the DEM
February 3, 2017, 03:38 |
kaveh
Rep Power: 9 |
February 3, 2017, 10:13 |
Rep Power: 9 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Seed particle and trap it in a channel by CFX | andox23 | CFX | 1 | April 24, 2013 07:21 |
Seed particle and trap it in a channel by CFX | andox23 | Main CFD Forum | 0 | April 15, 2013 11:01 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
