How to input a UDF code for simulaing particle-laden flow |
September 10, 2019, 02:23 |
Evan Huang
Rep Power: 8 |
Hi
I am dealing with the problem simulating a circular cylinder in a wind tunnel with air (carried fluid) and solid particles(dispersed phase), the Reynolds number is around 3900 and I am done with the single-phase(air) part with importing the UDF function for the experiments inlet and boundary conditions to Ansys Fluent 18, but now I want to add three source term for my particles' motion which are momentum, k, and epsilon. So my questions are 1. How should I choose the multiphase model in Fluent, for example, DEM, DPM or ...? 2. How to add source terms to it? and the code? 3. I also want to simulate the adhesion of particles, How to achieve? 4. Is there any examples or code related to my problem that I can consult? Thank you for helping! |
Display Modes | |
UDF for multicomponent particle vaporization | Mohsin | Fluent UDF and Scheme Programming | 17 | January 27, 2021 03:57 |
Using input parameters (velocity inlet) in UDFs - bad UDF? | student_1994 | Fluent UDF and Scheme Programming | 6 | September 14, 2018 21:31 |
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 09:33 |
UDF code help solve reaction rate equation palm oil | zirkov | Fluent UDF and Scheme Programming | 0 | February 13, 2017 11:34 |
write code UDF Fluent solve kinetic reaction rate equation palm oil | zirkov | FLUENT | 0 | February 13, 2017 11:16 |
