How to define oil as disperse phase and water as continuous phase on same inlet? |
February 2, 2022, 17:46 |
Muhammad Atif
Rep Power: 6 |
I am very new to multiphase analysis. I am running an analysis of a control valve with oil in water as fluid. I understand how to define boundary conditions for multiphase inlet but when I run analysis both phases are uniformly mixed at inlet, however, in reality there are oil droplets in the upstream pipes that pass through the valve body and break down into smaller droplets. Is there a way to define oil droplets coming from inlet? currently, I am just defining velocity and volume fraction and you can see the picture attached that the flow is uniform near the inlet side and later oil starts accumulating on the top side. Any suggestion would be highly appreciated. Thanks Muhammad |
inlet bc, multiphase boundary, oil and gas |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
Modelling 2 phase flow (oil & water) in a pipe | Ash95 | STAR-CCM+ | 0 | August 4, 2016 10:13 |
Two phase flow of air and water with two inlet | amin.shuvo | FLUENT | 5 | August 18, 2015 05:49 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
