Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Number of particles based on mass flow rate in DPM
Like Tree3Likes
  • 3 Post By BHUVANESH
Old   April 24, 2018, 01:37
Default Number of particles based on mass flow rate in DPM
Saptarshi is on a distinguished road
Hi everyone,
I am trying to simulate Al2O3-water nanofluid flow through a plane 2D channel using DPM. Mass flow rate of nanoparticle is 0.06498 kg/s. I am using surface injection where the number of particles are 60 as the number of cell faces are 60 according to my geometry. Nanoparticle diameter is 20 nm and density is 3880 kg/m3. So, each nanoparticle has a mass of 1.625*10^(-20) kg. So, for each injection 60 particles are entering into the domain which have a total mass of 9.75*10^(-19) kg. So, I am confused how fluent adjust the mass flow rate per second? If I increase the mass flow rate keeping the number of cells same at inlet, then how Fluent adjust it? I have searched in earlier forum. But not able to understand properly . Please help me
Saptarshi is offline   Reply With Quote
Old   May 24, 2018, 08:49
BHUVANESH
BHUVANESH is on a distinguished road
The injection is wrt timestep. The surface injection will be a parcel and not a particle.
No of particles in single parcel = (total mass flowrate*time step)/(no of parcels*mass of a single particle)
BHUVANESH is offline   Reply With Quote
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
