-   Fluent Multiphase (https://www.cfd-online.com/Forums/fluent-multiphase/)
-   -   Add Young's Modulus and Poisson Ratio to a material into Fluent (https://www.cfd-online.com/Forums/fluent-multiphase/202263-add-youngs-modulus-poisson-ratio-material-into-fluent.html)
florian.crepin May 25, 2018 11:46
Hi everyone,
I work on ANSYS Fluent to model a gel motion passing through a constricted channel.
I would like to create a new material for my gel with his own properties (Young’s Modulus, Poisson Ratio, Density). But when I create a new material in Fluent, the only properties that I can input are density, viscosity and others, but I can’t add the young’s modulus and poisson ratio. Is it possible to do? And how can I do?
I heard that we could use a User Defined Material Database, but on the examples I saw, I’ve never seen any Young’s modulus or Poisson ratio. Is it possible to add them? If yes, what would be the syntax?
If you have any other comments on how can I model this phenomena (gel motion through a constricted channel), it is highly appreciated.
Thank you very much in advance
