Laminar flow boiling of water in microchannel |
July 4, 2017, 13:22 |
Amitav tikadar
Rep Power: 8 |
Hello everyone,
I am new in Ansys Fluent multiphase flow simulation. For my research I have to simulate laminar flow boiling (Sub-cooled and Saturated regime) in microchannel of hydraulic diameter of 500 micrometer and I am applying constant heat flux from the bottom. Inlet water temperature is 20 DegC. But I am confused which multiphase model of fluent would be most suitable for my simulation and should I need to write any UDF? If someone can help me in this regard, then it would be very helpful for me? |
August 5, 2018, 13:47 |
Mehdi Asghari
Rep Power: 16 |
As I know, there are some methods for phase change simulation by interface tracking such as VOF, LS or FT (front tracking) method.
Do you investigate on implementing of these methods by using UDF's into Ansys Fluent? |
flow boiling, micro channel, mixture model, user defined function |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
flow analysis of a submerged water turbine in Ansys 13 | Anwerizer | CFX | 4 | September 17, 2014 08:54 |
Please**need help on Tow phase flow ( water & steam water) analysis** | ali_kntu | CFX | 2 | December 19, 2013 16:15 |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
Boiling of water with hot air | Dr. Flow Squad | CFX | 2 | July 27, 2009 07:37 |
