March 30, 2020, 16:01 |
Unexpected Behavior of Fluent (Hoops error)
Raj
Rep Power: 6 |
Hello all,
I know it might be a technical error, but I just wanted to know. It is common or something unusual. Everything was working fine until I was trying for streamlines in post-processing. "The program can't find the hoops2300_x64_x140.dll is missing from your computer. Try reinstalling to fix this problem." P.S: I have not deleted or modified or updated or changed the folder of the directory. In spite, I got this error. Any kind of info or help would be appreciated. Thank you Raj |
March 31, 2020, 05:58 |
Garbage Collector
It is possible that the buffer or cache is filled. You need to use the garbage collector to clear it up. Issue following command before displaying streamlines
(begin (gc) (cx-send '(gc))) Or it could be that you do not have OpenGL working. Then set HOOPS_DRIVER variable to value of x11. Or you can start Fluent with the command line option -driver x11
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 1, 2020, 08:15 |
Raj
Rep Power: 6 |
Wow. That was very useful.
Thank you Vinerm Raj |
April 1, 2020, 08:29 |
Good
Nice to know that.
Display Modes | |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 07:25 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
