Crystal agglomeration
I am having some problems regarding the agglomeration of crystals during crystallisation and seeking for your helps here. I tried including the Lou model and the turbulence model for crystal agglomeration in my crystallisation of Kcl from aqueous solution; the results were unreasonable when compared with the crystallisation without the agglomeration I ran before. (size was smaller and the total number was larger) Then, I tried enabling the Reaction (in the Phase interaction, under the Multiphase section) and set the transfer from crystal to crystal, thinking it would be quite similar to cases where I have reaction from solute to crystals before. However, the solution did not converge. Please give some thought on the problems if you have any idea. Thank you all! |
Hi, I'm trying to learn the crystallization now, do you have any tutorial for me ?? thank you ~~
Crystallization and Crystal agglomeration
What type of crystallization process are you studying? Crystallization can be done using solidification-melting model or using Population Balance Model. Search for tutorials related to these two models.
Tutorial
I am afraid I do not have any tutorial files for any thing. However, I am sure there are plenty of those online. If you face issue with setup or convergence or post-processing or results interpretation, you can certainly get response from Forum but as far as files are concerned, I won't be able to comment.
sure, thank you. I just saw the PBM tutorial, includes only those steps necessary for the population balance model itself; but it need to set up other models, boundary conditions, and so on by myself. I'm trying to find a full tutorial.
Pbm
Look for species transport and Eulerian multiphase tutorials. You would require species transport to model K and Cl and multiphase to model its various phases and agglomeration.
