increment in temperature of two-phase flow
Hello every one
I’m trying to simulate the evaporation of R410a in fluent. These are some information about my case: A 2-d axisymmetric smooth tube, Refrigerant enters to the tube, diameter=9.52mm & length = 3000mm inlet vapor quality = 0.2 Constant heat flux on the wall = 15 kw/m2 VOF multi-phase model, turbulence model: k-e standard, transient method, & time step = 1e-04 I put the liquid and vapor state of R410 in fluent material library. I used DuPont released information of R410. when I plot temperature in outflow, there is a huge increment in temperature of mixture while the vapor quality is 0.4, it means that before all refrigerant transfer to vapor, the temperature began to increase, & as all we know that is impossible in reality. Actually I repeated the simulation with water liquid and vapor instead of R410, but the result was same. Does anyone have any idea why is this happening? regards |
