December 6, 2019, 06:27 |
Condensation Microchannel VOF
Nicola Benvenuti
currently i'm working on a multiphase cfd simulation on Ansys Fluent. I'm trying to simulate the condensation process of r134a (refrigerant) in a veretical microchannel 3.4mm wide and 300mm. The vapour enters at saturation conditions and volume fraction 1. The free stream velocity is 1.99 m/s (G=100 kg/s; density=50.085 kg/m^3). I'm working in a 2D axysimmetric geometry. The grid is a structured mesh with 510000 and y+ =1. I chose the k-w SST model with low reynolds correction and implicit formulation for VOF, as i'm trying to obtain a stationary result. Moreover i wrote a UDF to implement the Lee Model for condensation, defining the Mass Transfer properties. Right now I'm really struggling to obtain a good convergence of the continuity equation. Indeed the mass flow rate difference between inlet and outlet increases at first and the start to fluctuate. Any Suggestion? Thanks for your attention! |
April 5, 2022, 05:05 |
Neel
Rep Power: 7 |
What coefficients are you using for Lee's Model? This coefficients have strong impact on mass balance.
condensation, continuity equation, microchannel, vof multiphase |
Condensation VOF | artem929292 | FLUENT | 1 | May 21, 2017 13:22 |
Evaporation and condensation model in VOF | ic3lemon | Fluent Multiphase | 0 | December 12, 2015 06:56 |
vof condensation | vivekanand | Fluent Multiphase | 3 | April 14, 2015 11:35 |
VOF based condensation in microchannel. | vivekanand | FLUENT | 0 | April 8, 2015 05:40 |
VOF - NO Condensation !!!!. | JSM | FLUENT | 2 | May 12, 2012 09:08 |
