Multiphase basics problem
5 Attachment(s)
It's been several months I work on multiphase problem. I'm now at my limit and I start from the begining which is to only have a simulation of wave without any problems. So for that I decided to make a domain which is -30750mm long with 6750mm between the inlet and the origin on the X axis. -5000mm tall and 14115mm down on the Z axis -6500mm long on the y axis I made 2 volume which has the same face on the plan XY. There it is for the geometry. For the mesh I used 3 edge sizing functions. -one that have the edge which go from the top and bottom to the middle -one have all the edge on the X axis. -one which got all the edge on the Y axis. On fluent I use "Double precision" and 4processes on parallel on local. I use volume fraction I enable level vof, wave BC, body force. I put the water on phase 2 . I initialise the simulation with my inlet and with flat surface. And when I run the simulation I use timestep = 0.01s 1000 timesteps 150 iterations/timestep So everything I did on fluent, is on picture with the message. Attachment 74183 Attachment 74185 Attachment 74186 So my questions are : -why does my residuals 1 timesteps don't converge but stay constant (like IsFun)Attachment 74188 -why does my water/air interface isn't continuous and have some weird shape?Attachment 74189 Thank you in advance, if you need more informations ask me I can send my file if that's not enough. PS : Sorry if my english is not that great If there is too much mistakes. |
