Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
selection of higher order descritization for simulation of re entry parachute
Old   September 8, 2021, 05:58
Default selection of higher order descritization for simulation of re entry parachute
jean@cfd is on a distinguished road
Consider using higher order discretization for improved accuracy of the final solution. First-order discretization may be used in the initial solution.How can i do this for simulation of re entry capsule?
jean@cfd is offline   Reply With Quote
can you tell me best gradient, pressure & momentum order selection in fluent sanjiiv FLUENT 6 February 14, 2020 06:07
How to proceed to higher order solution convergence Abhinand FLUENT 0 July 27, 2017 09:01
Duplicate entry SpalartAllmaras in runtime selection table LESModel wenxu OpenFOAM Programming & Development 5 May 29, 2015 08:34
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 04:40
rhoSimplecFoam Mach0.8 no pressure values CFDnewbie147 OpenFOAM Running, Solving & CFD 16 November 23, 2013 05:58
