Fluent Multiphase simulation with one single-phase fluid |
April 11, 2020, 05:50 |
je young kim
Rep Power: 12 |
Hello all.
Currently, I am seting up the simulation of a simple heat exchanger (shell-tube type). (Actually it is evaporator) Hot fluid water is used to heat up the cold fluid (ammonia). Both fluids are separated. Only, ammonia will go through evaporation and hot fluid water remains as water-liquid all the time. Hot fluid - single phase. cold fluid - two phases (ammonia-liquid, ammonia-vapor) I am using multiphase model (VOF or mixture) for cold fluid side. However, I would like to know how to setup the single-phase side. What methodology or model should be used? I will appreciate if you comment any thing. Thank you! |
April 11, 2020, 09:06 |
Multiphase
There are two ways to do this. Either add water as another phase and then, initialize with only water in water domain and ammonia and its vapor in the other domain. Another option is to use multicomponent (species transport) along with multiphase. Then, vapor can be one phase consisting of single specie, and liquid can be another phase consisting of water and ammonia. In this scenario as well, you just have to initialize with liquid volume fraction and water mass fraction of 1.0 in water domain and ammonia mass fraction of 1 in ammonia domain. I suppose the former option is better. You can also fix the volume fraction of water or ammonia and its vapor in both domains. You can only fix the value for secondary phases and not primary one.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
fluent, multiphase |
Single Phase simulation of an ejector | Lexicon | FLUENT | 3 | May 21, 2016 12:59 |
Single phase result file for multiphase simulation | Kushagra | CFX | 2 | July 8, 2008 21:14 |
Single phase simulation | Randheer Yadav | FLUENT | 2 | May 4, 2005 04:58 |
P4 1.5 or Dual P3 800EB on Gibabyte board | Danial | FLUENT | 4 | September 12, 2001 11:44 |
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 | Mohammad Al-Shannag | Main CFD Forum | 1 | July 16, 1999 11:28 |
