Problem related to multiphase flow with species transport equation |
July 23, 2020, 19:26 |
Anshuman Sinha
Rep Power: 7 |
I am modeling a multiphase flow with species transport equation. There are phases like a water column and overlying oil phase, and the water column is being stirred with DPM particles.
Both water and oil phases are defined as mixture material like water = h2o(liq) + hnco ( 0.001 fraction) , oil = diesel(liq) (0.99 fraction) + O2 (0.01 fraction). I'm using the implicit VOF method for interface tracking, and the PISO algorithm for p-v coupling. The results are not satisfactory when I'm using mixture materials for the phases. Initial condition: There are 3 phases of water, oil, and air. each lying above the other in order of density ( water, oil, air). Results ( when phases are not defined as a mixture ): These results are satisfactory with the experiments. Screenshot 2020-07-24 at 4.27.39 AM.jpg Results ( when phases are defined as a mixture ) : Screenshot 2020-07-24 at 4.40.44 AM.jpg These results when the material is defined as a mixture are not as expected. I'm also attaching the species plots and velocity profile plot: Screenshot 2020-07-24 at 4.50.03 AM.jpg. Thank you for all the help. |
dpm, mixture., multi phase, species tranport, vof method |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Species transport model problem | argeus | FLUENT | 8 | September 20, 2019 07:23 |
Weird problem in FLUENT Species Transport | Bin | ANSYS | 0 | September 24, 2013 20:41 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 02:52 |
