June 27, 2020, 02:21 |
How to compute the are of the interface
Anshuman Sinha
Rep Power: 7 |
I hawe a multiphase flow problem, I need to compute the following (1) interface Area between air and water in figure 1 , and (2) the distance marked as R in figure 2. Someone please help me in computing these
figure 1: Screenshot 2020-06-27 at 10.43.32 AM.jpg figure 2: Screenshot 2020-06-27 at 10.46.08 AM.jpg Thanks. |
June 29, 2020, 08:58 |
Using GUI
Rep Power: 7 |
You could: 1) make a iso-surface of VOF=0.5 for air. 2) cut the iso-surface with iso-clip with VOF water=1e-3 to 1. 3) use report->surface->area -> of the clipped surface, to get the area. 4) use report->surface ->min/max radial distance to get the radial extend. I think this will give you what you want, without resorting to UDF programming. BR. Torjo |
July 26, 2020, 21:03 |
#3 | |
Anshuman Sinha
Rep Power: 7 |
interface, multiphase |
Display Modes | |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
How to compute the global performance parameters at the interface? | eng.abdul | Fidelity CFD | 5 | September 8, 2018 01:23 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Problem with porous flow at multi-material interface with large permeability diff. | Hisham | OpenFOAM Programming & Development | 1 | June 3, 2016 11:51 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
