Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Gas solid counter-current flow in a horizontal pipe
Old   July 30, 2020, 18:16
Default Gas solid counter-current flow in a horizontal pipe
Ravi Agrawal
abc197 is on a distinguished road
Dear friends,
I am working on gas-solid mixing in a horizontal pipe. Both are flowing in countercurrent manner. Its a turbulent multiphase flow with gas being primary phase. I ma using transient Eulerian granular flow model. One end cross-section of pipe has been divided into two parts, one for gas inlet, while other for solids outlet. Similarly, other end cross-section of pipe are divided into gas outlet and solid inlet. Using velocity inlets for both inlets since I know velocities and mass flow rates of gas & solids. Using pressure outlets for both outlets.
Main issue I am facing here is that both solids and gas are trying to move out from both outlets. And since solid inlet & gas outlet lying on one face together. It results in highly impractical streamlines patterns. Each phase has a separate outlet. Experimentally also phases should go separate ways. There seems to be no provision for phase based outlet. I appreciate any suggestions. Attaching the domain.
Thanks
abc197 is offline   Reply With Quote
eulerian, gas-solid flow, granular
Multiphase flow in horizontal pipe weicuenbb Fluent Multiphase 1 October 24, 2019 04:18
heat transfer from hot gas flow to solid jws Main CFD Forum 1 March 28, 2019 09:58
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Simulation time for unsteady gas solid flow pandaba FLUENT 1 October 14, 2010 00:04
Gas solid flow in a pipe with 90 bend pandaba FLUENT 0 September 14, 2010 01:43
