Simulation for water jet spray using fluent multiphase |
August 16, 2020, 09:44 |
Hi guys, am new here. I would like to conduct a series of simulation of high pressure water jets into air with a fan nozzle angled at various angles to look at the primary breakup (fan angle) as well as the flow trajectory. I plan to start with a 2D analysis. My inlet velocity is in the range of approximately 140 m/s and outlet is 0 gauge pressure with atmospheric operating pressure.
Currently I am looking at multiphase VOF model to capture the interface between water and air with surface tension modelling and turbulence modeled with standard k-epsilon. however, I am unable to capture the desired variations in jet spray angle. So my question is really what dictates the spray angle in the vof analysis so that I am able to capture different spray angles. I did some research and it seems to be heavily tied to the nozzle geometry. but under cicumstances that i can not model the exact nozzle geometry, are there any thermodynamic properties which leads to this variation in spray angle that i can utilise in fluent? Also, I am using the student version so I am limited in the number of cells in my model. will it greatly affect the solution of the spray angle? thank you in advance for any assistance. |
multiphase flow, spray atomization, vof method, vof multiphase, water jet |
Spray Simulation in Fluent | machineengine | Fluent Multiphase | 0 | June 7, 2017 08:19 |
Thermal Simulation using Multiphase VOF model in Fluent | hari.poudyal47@gmail.com | Fluent Multiphase | 0 | July 20, 2015 11:31 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
LSR (Land speed record) car simulation on FLUENT | Maxime31850 | FLUENT | 2 | May 1, 2013 11:15 |
