Initial Values of Standard Initialization
1 Attachment(s)
Hello all,
I am dealing with the VOF model with multiple inlets and multiple outlets model. I have a doubt regarding settings. As I have a velocity inlet and pressure outlets. Basically, when I check my results after simulation the pressure at outlets should show as zero. But it is showing as 12000dyne/cm^2. My model has a very low velocity of around 0.0068cm/s. It should not have pressure at outlets in reality. I am using a pressure drop expression at outlets. So, I cannot use hybrid initialization. But, in standard initialization, I see initial values very low. Might this be a problem? I am not sure what is wrong! Please help me if you can? (Please excue me if my explanation is bad) Thank you Raj |
