September 12, 2020, 10:50 |
multiphase cell and face temperature
SAJA AL-RIFAI
Rep Power: 6 |
hello,
I wrote a UDF to calculate face and cell temperature and use it to adjust some of the values using the Adjust function. In my case I have mixture of gases including the water vapor (phase 1) and water liquid (phase 2). My UDF should loop over the phase 1 to calculate condensation of water vapor on a solid wall using a specific functions. however, the problem is the cell temperature and face temperature is very high and I have very low condensation, when I go to Ansys results and calculate the surface temperature (average, maximum, and minimum) on the same wall, I got a very satisfied results and within the range of what I need to condensate the water vapor compared to the one calculated by the UDF. is the UDF calculate the temperature of the water vapor at that wall and its shadow? part of my UDF code (this part inside the adjust function): : : .... mp_thread_loop_f(tf, mixture_domain, pt) if (DOMAIN_ID(tf) == 2) /*ID for mixture of gas phase 1*/ { begin_f_loop(f,tf) { tc = THREAD_T0(tf); c = F_C0(f,tf); pt = THREAD_SUB_THREADS(tc); ti = pt[0]; cell_temp = C_T(c,ti); /*very high compared to the wall temperature wall */ wall_temp = F_T(f,tf); /*same very high*/ } ..... : : |
Display Modes | |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
