Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian-Eulerian model droplet forces
Old   April 8, 2021, 08:33
Default Eulerian-Eulerian model droplet forces
Sean Petley
s.petley is on a distinguished road
I'm simulating a hydrocyclone separator and looking at efficiency for different oil droplet sizes.
I've run mesh sensitivity study and observed better agreement with fine mesh accross all droplet diameters (not surprising). But I'm still not getting good agreement with small diameter droplets with affordable mesh resolution.
The pressure gradient and velocities check out ok so I'm wondering what other forces are not 'mesh independant' and if it is possible to look at the droplet drag? or look at the forces on droplets/oil phase? I know this can be done in DPM but is it also possible in the Eulerian model?
Thanks
s.petley is offline   Reply With Quote
Old   April 20, 2021, 03:50
België
InsPyro is on a distinguished road
You can look at drag and lift forces although DPM is normally used for cyclones.
You could also check the turbulence model, as k-eps does not fully capture the stresses in a the highly curved flow.
InsPyro is offline   Reply With Quote
Eulerian model theory hamed.majeed FLUENT 7 September 4, 2018 07:16
Do I need to model secondary droplet breakup? quarterlbr Main CFD Forum 3 July 5, 2017 02:21
Solidification model for Eulerian Mohamed Mousa STAR-CCM+ 0 January 1, 2017 15:25
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
2D VOF Droplet evaporation model. Multi-component problem nb92 Fluent Multiphase 0 February 28, 2014 10:36
