October 22, 2021, 04:22 |
Reversed flow in faces on pressure outlets
Rep Power: 4 |
I am simulating a 1-meter height 0.15-meter diameter of a cylindrical bubble column reactor. where the liquid is the primary phase and the air is the secondary phase. After initialization air is patched from 0.3 to 1 meter of column remaining water is filled initially from 0 to 0.3 meters of the column. While running the simulation, a message is shown that reversed flow in faces on pressure outlet in each iteration. Why is showing? please explain it?
air-water, bubble columns, multiphase flow |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
reversed flow in xxxx faces on pressure outlet | franzdrs | FLUENT | 8 | January 4, 2020 20:12 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
