January 14, 2020, 11:12 |
Parcels/particles injection
MMatt
Rep Power: 12 |
I have an issue regarding parcels/particles in Fluent. I want to use a surface as a starting point to send particles to my fluid domain. I have set that properly (I think) in the injection dialog box, meaning I have set the correct surface, the particle diameter, and the flow rate. However, no matter which time step I use, fluent always injects the same number of particles into the domain. How can I control that number? I have a defined number of particles per second that I want to introduce to the domain. Thanks in advance! |
January 28, 2020, 09:02 |
Faces on the Surface
Hi
The number of particles injected depend up on the number of mesh faces on the injection surface. If you wish to inject specified number, then do not use surface injection. Use single, or group, or FILE, or UDF. Another alternative is to ensure that the surface has required number of faces.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
November 12, 2021, 06:51 |
Jordan
Rep Power: 4 |
For the "file " injection I created a file using ((x y z u v w diameter temperature mass-flow) name)
However how would this help in getting a specified number of particles to be tracked. I have a surface that has 900 cells and I need to check for 20000,30000,60000 number of particles from this surface |
Injection injection-0: LOST 2 out of 20 injection locations | attaullah | FLUENT | 17 | March 2, 2023 10:31 |
UDF for particle injection using file | shahjehan | Fluent UDF and Scheme Programming | 2 | June 28, 2020 10:44 |
file injection.: continuity fail; volume injection.: wrong total mass | blerli_91 | Fluent Multiphase | 6 | October 2, 2018 05:34 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
jou file command for the injection! | asal | FLUENT | 0 | June 4, 2013 04:15 |
