FLUENT VOF -simulation metal rod melting problem |
January 28, 2022, 06:06 |
Rep Power: 4 |
Hi
I use FLUENT VOF to simulate a steel rod shape changing during melting process. My simulation condition:transient,VOF(steel-air),UDF(surface tension,recoil force in xyz direction),gravity. In the project,the steel rod change its shape in temperature 300K. The material setting steel's melting point is 1700K. I think steel in temperature of 300K should be solid in my case,and would not have shape changing. Is it possible for a material change its shape when its temperature is below melting point in vof model? Or I set something wrong?Could someone please help me with it? Thank you. |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Transient mode simulation (VoF model) mesh independence study problem | yulu | FLUENT | 4 | September 20, 2016 17:30 |
Desuperheater simulation problem in fluent | kortaz | System Analysis | 0 | April 20, 2016 05:03 |
Melting Simulation by Ansys Fluent | mohammad razzaghian | FLUENT | 0 | July 25, 2014 17:37 |
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 | Mohammad Al-Shannag | Main CFD Forum | 1 | July 16, 1999 11:28 |
