Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to maintain air at a constant pressure in multiphase flows?
Old   June 18, 2022, 09:13
Default How to maintain air at a constant pressure in multiphase flows?
Tutun
Tutun2507 is on a distinguished road
Hello!
I am trying to reproduce the results given in a paper in Ansys Fluent using VOF model - it is basically a gravity-driven flow of a thin liquid film over an inclined plane. The inclined plane is hydrophobic in nature and is ribbed and contains grooves filled with air. The air above the liquid film as well as the air trapped in the grooves are both at a constant pressure of 1 atm.
I started the simulation by patching a desired height with the liquid film above the groove with air filling up the groove. Initially at t=0, the liquid-gas interface is flat. The initial pressure in the entire domain is 1 atm. According to the paper, the liquid-air interface should curve downwards. Unfortunately, when I start running the transient simulation, the pressure in the air in the groove starts increasing and due to the Laplace pressure difference, the interface curves upwards.
So my question is: Is there any way to keep the pressure in the air constant throughout the entire length of the transient simulation?
Tutun2507 is offline   Reply With Quote
Supersonic 2D Ramp Air Intake Outlet Back Pressure BarisBicakci SU2 7 March 15, 2024 18:45
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
