Latent Heat Cannot be Less than zero
Hi all, I'm practicing multiphase analysis in fluent,
my problem involves air, R134a liquid & R134a vapour I have assign the properties and while going through initialization i have noticed this error. Compute Node ID: 3 From-phase Domain ID: 1 To-phase Domain ID: 2 Cell Number: 0 Latent Heat: -294579 ERROR: Latent heat cannot be less than zero! could you please help me to understand and resolve this error |
have u found out how to solve the error
yes, it is solved
Can u share how did u solve it please
sure, in ansys it is suggested to consider latent heat for refrigerant in liquid material as zero
in ansys fluent, latent heat is calculated from standard state enthalpy of phase participating in mass exchange only enthalpy difference matters hvl(enthalpy total or vapour & liquid at ref temperature)= hv(vapour enthalpy)-hl(liquid enthalpy) at reference temperatures so it is better to consider liquid enthalpy as zero |
it is better to use
Tref= Tsat hv, Tsat= hvl,Tsat |
So in a evaporation condensation cycle should i put sse of water zero and air as it is
Hello where can I find Tref and Tsat in fluent? Thank you |
