Inhomogeneous Discrete Population Balance Model - Load File Format
I am trying to use the Load File... option in the Fluent Multiphase Eulerian Population Balance Model dialogue on Fluent 2021R1. I have had success in formatting the load file for the Homogeneous Discrete model as shown in a text file: 1e-06 9.00000000000000e-06 1.80000000000000e-05 2.70000000000000e-05 3.60000000000000e-05 4.50000000000000e-05 5.40000000000000e-05 6.30000000000000e-05 7.20000000000000e-05 8.10000000000000e-05 9.00000000000000e-05 9.90000000000000e-05 0.000108000000000000 0.000117000000000000 0.000126000000000000 0.000135000000000000 0.000144000000000000 0.000153000000000000 0.000162000000000000 0.000171000000000000 0.000180000000000000 0.000189000000000000 0.000198000000000000 0.000207000000000000 0.000216000000000000 0.000225000000000000 I need to know how to format the file for the inhomogeneous discrete model, as I need to control the bin sizes manually instead of using the Geometric Ratio option. The Fluent Theory Guide section on Population Balance Models indicates the following as an example: (("air-1" (0.01 0.02 0.03)) It states that the name of the phase must be included. However, when I try this format, I receive the following error: Error: eof inside list Error Object: () By playing around with the formatting a bit, I have also received these errors: Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: () OR Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: 0.01 OR Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: "phase-2" Does anyone know how to properly format the file? Thanks. Best, Keegan |
Formatting for Inhomogeneous Load File
I figured out the formatting for this file type. The example below is for two particle phases with 3 bins for each phase.
The Fluent User Guide is missing a parenthesis. Example: ( ("phase-2" (0.1 0.2 0.3)) ("phase-3" (0.01 0.02 0.03)) ) |
