Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Convergence problem fludized bed
Old   July 20, 2022, 22:02
Default Convergence problem fludized bed
bonimio is on a distinguished road
Hello. I'm trying to simulate a 3D fludized bed using a eulerian-eulerian approach. When I restrict the inlet area, fluent diverges and show me the message: floating point exception. I'm using gidaspow for granular viscosity and drag coefficient.
inlet velocity: 0.12 m/s
diameter of particles: 0.000163m
density: 2820 kg/m3
base radius: 0.073m
inlet radius: 0.01m
step size: 0.001
element size: 0.005
If my inlet area is the base area (0.073m of radius) the is no problem, but when I put the named section with 0.01m of radius, the problem diverge after 20 interections.
Thank you very much in advance
bonimio is offline   Reply With Quote
Old   July 21, 2022, 04:25
Void_CFD-user
Indra is on a distinguished road
density: 2820 kg/m3
base radius: 0.073m
inlet radius: 0.01m
step size: 0.001
element size: 0.005
If my inlet area is the base area (0.073m of radius) the is no problem, but when I put the named section with 0.01m of radius, the problem diverge after 20 interactions.
I guess one of the immediate things to do is reduce time step size. What sort of pressure discretisation are you using? I would recommend using PRESTO! or Body force weighted. Also, you might wanna try switching to explicit scheme under multiphase model if you are running a trasnient sim. But don't change everything at once!
A general advice, in the tui you can type /report/mphase-summary and select 1 for verbosity. It will give you all sorts of recommendation and suumary
Indra is offline   Reply With Quote
Old   August 7, 2022, 19:03
Thanks for replying me . Since I saw your answer, I'm trying to simulate my case. I'm using PRESTO and change time step to 1^-5, but the simulation time incresed a lot, so I've change the element size to 1^-2. With those changes, I can simulate, but the residuals periodicaly show-me that (see the figure). Do you think changing the element size and reducing the time step, the behaviour will change?
Convergence problem and the Mach problem in supersonic model ranxiaoran FLUENT 2 July 28, 2021 12:27
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 12:12
Force can not converge colopolo CFX 13 October 4, 2011 22:03
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
