October 20, 2022, 11:01 |
Mach Number Multiphase Mixture Model Fluent
Rep Power: 6 |
I am simulating a hydraulic ejector with liquid water as working fluid and air as secondary fluid. I am using the mixture model in fluent.
When looking at the contour plots for the mach number I have strange results. According to Fluent the Mach number of air is 0.06 which seems right to me. Temperature is 300 K and velocity is around 21 m/s. Now the "but" and strange part: the mach number of the mixture is 0.86. I havnt found the formula how fluent calculates the mach number for the mixture. By decreasing the diamter of the pipe my flow becomes supersonic, which is just impossible at 300 K and a maximum velocity of approx. 40 m/s. By looking at the pressure plot it seems that I have a compression shock. Any ideas? It seems like a coding error to me. |
mixture multiphase model, super sonic |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
