[Sponsors] | |||||
Md Nabil
Rep Power: 0 ![]() |
I am trying to simulate the fluid(water) flow through a closed loop fluid circuit. (attached image). The red rectangular box is a reservoir from where water needs to be pumped through the full circuit. The circuit(blue) is containing air. I didn't put the pump since it will add complexity. I wanted to adjust the BCs so that they can simulate the scenario.
From the bottom of reservoir comes the tube where I placed my pressure inlet BC. I calculated the static pressure to be 5880Pa and inserted it as the total gauge pressure. The loop ends at the top of the reservoir where I put a 'mass flow outlet' BC. I put 1.667e-3 kg/s. I used PISO solver. Under relaxation factors are quite low. Pressure 0.3, Momentum 0.4. I am not sure about them though. But the solution never converges. after 100 iterations it shows 'floating point exception'. And the continuity residual curve is fully diverged. If I don't put any BCs and just let gravity to flow the water, the solution converges. But as soon as I am trying to adjust the BC to simulate a pump, it is not working. Am I putting the BCs wrong? or the settings? The mesh metrics are quite good. (avg aspect ratioi 1.02, orthogonal quality 0.997). Though around the inlet and outlet regions they are a bit low. I am trying to find the solution everywhere. But could not guess where the problem is coming from. |
| Tags |
| multiphase flow, pump boundary condition |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Is recirculating flow is free vortex or forced vortex? | FluidKo | Main CFD Forum | 11 | July 21, 2022 07:21 |
| unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 18:22 |
| Very strange/incorrect flow solution all of a sudden. | bndrylyr | FLUENT | 0 | March 21, 2017 16:44 |
| solution not converging for steady laminar flow | anillor | FLUENT | 0 | February 3, 2017 00:52 |
| Boudaries for bouynat driven flow with additional mass flux at inlet | Charon | CFX | 2 | April 27, 2013 09:02 |
