Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem with Multiphase model with VOF in Ansys Fluent
Old   February 20, 2025, 01:34
Default Problem with Multiphase model with VOF in Ansys Fluent
vjo
vjo is on a distinguished road
Dear experts,
Please bear with me.
As per my understanding VOF model cannot generate mass during phase change in boiling or condensation. Therefore Ansys provides an in-built 'Evaporation and condensation model or LEE model' with it. Now if we dont want to use this model, we can provide 'mass source terms' using a UDF into the Ansys and these will be added to governing equations and will act as mass generation.
Therefore i DID NOT SELECT 'evaporation and condensation' model in FLuent and used following UDF in ansys for source terms. BUT no mass is being generated (no bubble formation)..!! My simulation is for flow boiling of water in a channel with constant heat flux. Please help me.!!
DEFINE_SOURCE(liq_src, cell, pri_th, dS, eqn)
Thread *mix_th, *sec_th;
real l_mass;
mix_th = THREAD_SUPER_THREAD(pri_th);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
l_mass = 0;
if (T_sat != 0.0) {
// Perform the calculation involving T_sat
if (C_T(cell, mix_th) >= T_sat) {
l_mass = -0.1 * C_VOF(cell, pri_th) * C_R(cell, pri_th)
* fabs((C_T(cell, pri_th) - T_sat) / T_sat);
dS[eqn] = -0.1 * C_R(cell, pri_th)
else {
l_mass = 0.1 * C_VOF(cell, sec_th) * C_R(cell, sec_th)
* fabs((T_sat - C_T(cell, mix_th)) / T_sat);
dS[eqn] = 0.1 * C_VOF(cell, sec_th)
return l_mass;
DEFINE_SOURCE(vap_src, cell, sec_th, dS, eqn)
Thread *mix_th, *pri_th;
real v_mass;
mix_th = THREAD_SUPER_THREAD(sec_th);
pri_th = THREAD_SUB_THREAD(mix_th, 0);
v_mass = 0;
if (T_sat != 0.0) {
v_mass = 0.1 * C_VOF(cell, pri_th) * C_R(cell, pri_th)
* fabs((C_T(cell, mix_th) - T_sat) / T_sat);
dS[eqn] = 0.1 * C_VOF(cell, pri_th)
else {
v_mass = -0.1 * C_VOF(cell, sec_th) * C_R(cell, sec_th)
dS[eqn] = -0.1 * C_R(cell, sec_th)
return v_mass;
DEFINE_SOURCE(enrg_src, cell, mix_th, dS, eqn)
Thread *pri_th, *sec_th;
real m_dot, delta_T;
delta_T = fabs(C_T(cell, mix_th) - T_sat);
m_dot = -0.1 * C_VOF(cell, pri_th) * C_R(cell, pri_th) * delta_T / T_sat;
dS[eqn] = -0.1* C_VOF(cell, pri_th) * C_R(cell, pri_th) / T_sat;
else {
m_dot = 0.1 * C_VOF(cell, sec_th) * C_R(cell, sec_th) * delta_T / T_sat;
dS[eqn] = 0.1 * C_VOF(cell, sec_th) * C_R(cell, sec_th) / T_sat;
return (H_LV * m_dot);
vjo is offline   Reply With Quote
fluent, multi phase flow, udf code, vof model
Is the built-in NOx model of Fluent not compatible with the multiphase flow models? swtbkim FLUENT 1 October 21, 2020 23:12
The problem of Stiff Chemistry Solver in Multiphase model shenzhou1987 FLUENT 1 January 11, 2016 03:52
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
VOF multiphase - Validity of Fluent ? manxu FLUENT 2 January 2, 2014 12:17
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
