Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase simulation in a closed centrifugal chamber
Old   April 1, 2025, 06:13
Post Multiphase simulation in a closed centrifugal chamber
Saurav Rath
Saurav_Rath is on a distinguished road
Hello everyone,
I am seeking help for a multiphase simulation in a centrifugal chamber.
Objective: Obtain distribution of different phases within the chamber and looking at impact of different densities of solids, viscosity of liquid phase.
Geometry (attached), mesh (poly-hexcore with min cell size ~ 0.05mm)
Materials:
1. Primary - Liquid (same as water)
2. Secondary - Air
3. Secondary - Solids (rho=1077kg/m3 and viscosity = 1.2cP)
Initialization:
1. Patching air with cell register = 1
2. Patching cells with cell register = 0.01
Current case:
- Mixture model with solids as granular phase, implicit
- Whole chamber is rotating so using frame motion at 2100 RPM (in y direction)
- Running transient simulation with delT=1e-5
Challenge:
- Floating point exception within few timesteps
- Even if it works at very low timesteps, the mass of liquid phase is fluctuating leading to mass imbalance.
I have tried converging (to 1e-3 for now) at every timestep, reducing URFs, delT. But the simulation crashes or doesn't run as expected.
Many thanks,
Saurav
Saurav_Rath is offline   Reply With Quote
Old   April 5, 2025, 02:35
SHAIZA TALIB
SHAIZA TALIB is on a distinguished road
hello, i have a question about how you define the inlet velocities for multiple materials. i am also learning about it. want to see the wind_wave oupling. And I have a 2D channel with height of 5m, 3m water and 2m air. I am using Fluent , K epsilon model plus VOF. Just want to know how to define the inlet velocites.
SHAIZA TALIB is offline   Reply With Quote
Old   May 14, 2025, 09:21
Saurav Rath
If I understand correctly, inlet velocities can be provided using multiphase tab in BC. Since it is multiphase, you would have to provide values for each phase.
closed system, multiphase mixture
Issue with Centrifugal Pump Simulation in ANSYS Fluent - Fluid Not Rotating Mustapha@ FLUENT 0 August 22, 2024 04:22
Multiphase Flow Simulation AS_Aero STAR-CCM+ 1 March 18, 2018 23:14
Why opening boundary for multiphase simulation must set Volume Fraction of each phase TerryNiu CFX 2 March 13, 2018 06:49
Which Multiphase Model Should be selected in Fluent for my below described simulation oberstar Fluent Multiphase 0 September 28, 2017 12:05
Multiphase Simulation dungsidietquy FLUENT 4 November 4, 2009 13:46
