Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Particles Injection in Cyclone
Like Tree1Likes
  • 1 Post By C_Matar
Old   May 12, 2025, 17:09
Default Particles Injection in Cyclone
Chris
C_Matar is on a distinguished road
Hello. I have simulated with RSM (steady time) an experiment by Hoekstra. The tangential and axial velocities are very close to the experimental values. I then inject 11 classes of particles from 0.5 μm to 5 μm. The weird is that the efficiency if the smaller particles (0.5, 0.6, 0.8 μm) are greater than 1 and 1.3 μm, and then the efficiency values rise again. The lower wall of the dustbin is set to "trap" and the other walls to "reflect". There are no experimental data on collection efficiency per particle class. d50 is calculated and then a logistic function is used for overall efficiency. Due to low particle loadings, one way coupling is selected. Any thoughts? Anything would be helpful. Thanks in advance.
d.vincent likes this.
C_Matar is offline   Reply With Quote
cyclone, fluent, particles
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 07:21
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 08:51
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Straight through cyclone with particles rogerhoffmann CFX 1 May 21, 2012 18:42
