Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Error while trying to run a UDF for drag coefficient
Old   May 20, 2025, 03:58
Default Error while trying to run a UDF for drag coefficient
akg
akg is on a distinguished road
I'm a new user in ANSYS-FLUENT and I'm working in a quite simple Eulerian Multiphase model with liquid as the primary phase and vapour as the secondary dispersed one.
I'm trying to implement an UDF in order to model drag coefficient using the AIAD model, for which I need to acces to the Liquid Volume Fraction Gradient. The error I am getting is attached below. As I understand this error means there is a segmentation fault, and it may be caused because I am trying to access gradient of volume fraction, but I am not really sure. Some help with this will be greatly appreciated.
The UDF Script is written as follows:
#include"udf.h"
#include"sg_mphase.h"
#defineALPHA_B_LIM0.3 /* Bubble limit volume fraction */
#defineALPHA_D_LIM0.3 /* Droplet limit volume fraction */
#defineCD_BUBBLE0.44 /* Drag coefficient for bubble regime */
#defineCD_DROPLET0.44 /* Drag coefficient for droplet regime */
#definea_B70.0 /* Blending function coefficient */
#definea_D70.0 /* Blending function coefficient */
#defined_B0.0001 /* Bubble diameter (m) */
#defined_D0.0001 /* Droplet diameter (m) */
DEFINE_EXCHANGE_PROPERTY(aiad_drag_force, cell, mix_thread, second_column_phase_index, first_column_phase_index)
Thread *prim_th, *sec_th;
real drag_force=0.0;
real alpha_prim, alpha_sec;
real A_B, A_D, A_fs;
real f_b, f_d, f_fs;
real C_D, C_Dfs, A;
real rho_prim, rho_sec, rho_iv;
real mu_prim, mu_sec;
real u_prim, u_sec, v_prim, v_sec, w_prim, w_sec;
real rel_vel_mag;
real tau_prim, tau_sec;
real grad_alphal_x, grad_alphal_y, grad_alphal_z;
real grad_alphav_x, grad_alphav_y, grad_alphav_z;
prim_th =THREAD_SUB_THREAD(mix_thread, first_column_phase_index);
sec_th =THREAD_SUB_THREAD(mix_thread, second_column_phase_index);
alpha_prim=C_VOF(cell, prim_th);
alpha_sec=C_VOF(cell, sec_th);
rho_prim=C_R(cell, prim_th);
rho_sec=C_R(cell, sec_th);
rho_iv=alpha_prim*rho_prim+alpha_sec*rho_sec;
mu_prim=C_MU_L(cell, prim_th);
mu_sec=C_MU_L(cell, sec_th);
u_prim=C_U(cell, prim_th);
v_prim=C_V(cell, prim_th);
w_prim=C_W(cell, prim_th);
u_sec=C_U(cell, sec_th);
v_sec=C_V(cell, sec_th);
w_sec=C_W(cell, sec_th);
rel_vel_mag=sqrt(pow(u_prim-u_sec, 2) + pow(v_prim-v_sec, 2) + pow(w_prim-w_sec, 2));
A_B=6.0*alpha_sec/d_B;
A_D=6.0*alpha_prim/d_D;
f_b=1.0/ (1.0+exp(a_B* (alpha_sec-ALPHA_B_LIM)));
f_d=1.0/ (1.0+exp(a_D* (alpha_prim-ALPHA_D_LIM)));
f_fs=1.0-f_b-f_d;
grad_alphav_x=C_VOF_G(cell, sec_th)[0];
grad_alphav_y=C_VOF_G(cell, sec_th)[1];
grad_alphav_z=C_VOF_G(cell, sec_th)[2];
grad_alphal_x=-grad_alphav_x;
grad_alphal_y=-grad_alphav_y;
grad_alphal_z=-grad_alphav_z;
A_fs=sqrt(grad_alphal_x*grad_alphal_x+
grad_alphal_y*grad_alphal_y+
grad_alphal_z*grad_alphal_z);
if (A_fs<1e-10) A_fs=1e-10;
tau_prim=mu_prim*sqrt(pow(C_DUDX(cell, prim_th)*grad_alphal_x/A_fs, 2) +
pow(C_DVDY(cell, prim_th)*grad_alphal_y/A_fs, 2) +
pow(C_DWDZ(cell, prim_th)*grad_alphal_z/A_fs, 2));
tau_sec=mu_sec*sqrt(pow(C_DUDX(cell, sec_th)*grad_alphav_x/A_fs, 2) +
pow(C_DVDY(cell, sec_th)*grad_alphav_y/A_fs, 2) +
pow(C_DWDZ(cell, sec_th)*grad_alphav_z/A_fs, 2));
if (rel_vel_mag<1e-10) rel_vel_mag=1e-10; /* avoid division by zero */
C_Dfs=2.0* (alpha_prim*tau_prim+alpha_sec*tau_sec) / (rho_iv*rel_vel_mag*rel_vel_mag);
/* Combined drag coefficient */
C_D=f_fs*C_Dfs+f_b*CD_BUBBLE+f_d*CD_DROPLET;
return C_D;
akg is offline   Reply With Quote
How to run a simple Fluent UDF Rcfd1 Fluent UDF and Scheme Programming 5 March 7, 2025 04:39
The UDF of Heat Transfer Coefficient In TFM Dinghc Fluent UDF and Scheme Programming 0 August 14, 2023 21:51
How to find heat transfer coefficient using UDF in internal turbulent flow YHH0123 Fluent UDF and Scheme Programming 0 December 5, 2022 00:35
UDF : Lift coefficient time history and Data sampling Bibill Fluent UDF and Scheme Programming 9 June 5, 2020 06:31
Lift coefficient UDF peaker007 Fluent UDF and Scheme Programming 0 November 24, 2011 22:10
