Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Two phase flow
Old   August 26, 2025, 11:32
Default Two phase flow
Masoud
Masoudrh is on a distinguished road
Hello everyone,
I hope you are doing well.
I need some guidance regarding a problem involving immiscible liquid–liquid two-phase flow.
The problem is as follows:
Two immiscible liquid phases are first thoroughly mixed using a mixer, and then the mixture is introduced into a separator. This separator consists of a rotating vessel that spins at high speed. As the two-phase mixture enters the separator, phase separation occurs due to the action of centrifugal force.
The main questions are:
Which multiphase model would be most appropriate for simulating this system?
In the absence of experimental data, how can the accuracy or validity of the simulation be verified?
Masoudrh is offline   Reply With Quote
Old   August 31, 2025, 16:39
Default volume of fluid
abirami
ABIRAMI is on a distinguished road
go for volume of fluid approach,
and you don't have experiment, go through some literatures and try to validate it first.
ABIRAMI is offline   Reply With Quote
fluent, seperation, two phase flow
Turbulence Eddy Freqency bounds error when using single phase flow vs two phase flow Eman Eal CFX 1 October 30, 2024 17:26
The secondary phase cannot flow within the primary phase gnakrammm FLUENT 0 May 12, 2024 21:45
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 22:57
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 20:01
