Simple UDF array question [Fluent]
Old   April 19, 2012, 01:41
Default Simple UDF array question [Fluent]
Patrick
Patrick1 is on a distinguished road
Edit: Solved..array positions start at 0 and not 1 in C
I'm making a simple UDF that is defined by a matrix of values, but am having problems in actually getting the UDF the access the matrix properly. Here's the bones of my code:
real velocity; /*velocity value*/
real matrix[2]; /*1D array storing 2 velocity values*/
int value; /*variable describing the array position eg. column 1,2..*/
matrix[1]=1.1;
matrix[2]=1.5;
value=1;
F_CENTROID(radi_pos,f,thread);
velocity=matrix[value]; /* <<<PROBLEM LINE /*
F_PROFILE(f, thread, position) = velocity;
This code does NOT work for me. However, if I replace the problem line with:
velocity=matrix[1]; or
velocity=matrix[2];
then my code works..so how can I access the matrix by an integer variable rather than by an actual integer?
Will post the full code if need be.
Thanks,
Patrick
Patrick1 is offline   Reply With Quote
udf
Problem with a simple UDF to calculate cell-averaged particle values kmayank FLUENT 1 January 18, 2011 01:40
question on UDF manual example ak6g08 FLUENT 0 June 25, 2009 11:58
UDF - Source Term Question Jacques FLUENT 0 December 8, 2008 13:40
Pb with simple Fluent UDF example for inlet francois FLUENT 0 October 9, 2008 10:34
easy UDF question Oleg FLUENT 4 March 17, 2008 07:07
