UDF for latent hear transfer between two phase
Old   May 21, 2012, 06:48
Default UDF for latent hear transfer between two phase
deepak
dkb_bg is on a distinguished road
Dear all
i am trying to model phase change from liquid to vapour .i am getting the phase change but temperature of liquid is not changing, but in actual practice it should decrease since latent heat is released from the liquid. what is the udf for this type of problem/or is there any other method to deal this problem
can anybody help me really i will be very grateful.
thanks
dkb_bg is offline   Reply With Quote
Old   May 21, 2012, 18:26
Default HI
Danial
Danial Q is on a distinguished road
Phase change occurs at constant temperature and heat will be added to liquid phase (not released) ,am I right? if system goes down to low temperature limits , means some sensible heat loss occured. I dont knw abt udf's but may be you should check your conditions set for system again. I am also dealing with phase change but in cfx not in fluent.
cheers
Danial Q is offline   Reply With Quote
Old   May 21, 2012, 23:23
deepak
Dear sir thanks for your guidance
my problem is adiabatic no heat source is there, and phase change is only due to drop in pressure below its saturation pressure.
UDF for heat transfer coefficient Shankar Fluent UDF and Scheme Programming 9 February 18, 2013 09:13
2 phase heat transfer Lexa FLUENT 1 November 3, 2011 08:38
Phase change heat transfer Lexa FLUENT 0 October 10, 2011 02:53
Which Code is Best for Two Phase, Heat Transfer earlc Main CFD Forum 0 September 23, 2005 20:26
UDF - Heat transfer coefficient kulasekharan FLUENT 3 August 12, 2004 07:09
