NEED HELP TO create UDF to define a boundary condition automatically
Old   May 21, 2012, 09:53
Default NEED HELP TO create UDF to define a boundary condition automatically
bon
bonna0271 is on a distinguished road
i must create a UDF to define a velocity inlet at the face of my box which is normal to "y axis" and which is the closest and the furthest will be a pressure outlet. and the other faces will be walls.
need a udf because i have many geometries and because the box has been separate in random faces.
bonna0271 is offline   Reply With Quote
Old   May 21, 2012, 10:11
James Willie
jwillie2000 is on a distinguished road
How are you setting up your case? Not sure if a udf macro exist for doing what you want. But you could use a journal file to help you automatically setup your entire Fluent case including defining your bcs. Jimmy
jwillie2000 is offline   Reply With Quote
Old   May 22, 2012, 03:20
bon
But like i said my boxes which enclosure my geometries are separate in 6 random faces. so i can't use a journal file
Old   May 22, 2012, 04:20
bon
If someone has an idee ???
UDF for inhomogenous Neumann boundary condition akhilesh Fluent UDF and Scheme Programming 3 December 24, 2012 11:14
Need help to define Boundary condition Chirag2302 FLUENT 6 May 7, 2012 06:51
[stressAnalysis] how to define a new boundary condition xck1986 OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 February 23, 2011 04:56
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
