DPM UDF - Segmentation Violation & Stack Backtrace |
February 23, 2009, 17:55 |
Hi All
I am working on my Masters Thesis which involves FLUENT modeling of particle deposition. I am a greenhorn when it comes to UDF's and the following is the first UDF I have ever created. The UDF is compiling without any errors and I am also able to choose it as a Boundary Condition in my setup. When I run the particle tracking though, I get the following error: Stack backtrace generated for node id 3 on signal 11 : Please include this information with any bug report you file on this issue /nfs/14/osu5206/.bashrc: line 1: module: command not found Primitive Error at Node 3: received Segmentation Violation I have the code below if that would help in debugging the problem. The BC is basically calculating the particle normal velocity and critical velocity, comparing the both and determining if particle sticks based on this condition. Any help would be greatly appreciated as I have a 5 day deadline to get this working. #include "udf.h" #include "dpm.h" #define nu_s 0.27 #define nu_p 0.27 #define YMIN 0.0 #define YMAX 0.4 #define UMEAN 1.0 #define B 1./7. #define DELOVRH 0.5 #define VISC 1.7894e-05 #define RGAS (UNIVERSAL_GAS_CONSTANT/MW) #define Tdatum 288.15 #define NUM_UDM 2 DEFINE_DPM_BC(deposition_bc, p, thread, f, f_normal, dim) { Domain *d; cell_t c; Thread *t; d=Get_Domain(1); real Tavg,Ep,vcr; /*real norm_coeff=1.; real tang_coeff=1.;*/ real vn=0.; real R=287.; real normal[3]; int i,idim=dim; real x[ND_ND]; for (i=0.; i<idim; i++) normal[i] = f_normal[i]; if(p->type==DPM_TYPE_INERT) { /*computing normal velocity*/ for(i=0.;i<idim;i++) vn += p->state.V[i]*normal[i]; /*computing critical velocity*/ Tavg = (F_T(f,t)+P_T(p))/2.; Ep = (3.*(pow(10.,20.)))*exp(-0.02365*Tavg); vcr = pow(((2.*Ep)/P_DIAM(p)),(10./7.)); /*particle continues its path - no sticking*/ if (vn > vcr) { return PATH_ACTIVE; } /*particle sticks*/ else { thread_loop_c(t,d) { begin_c_loop(c,t) { C_UDMI(c,t,0) += P_MASS(p); /*mass of particles deposited*/ } end_c_loop(c,t) } return PATH_ABORT; } } } |
July 11, 2009, 05:33 |
any solution
Mayank Kumar
Rep Power: 16 |
Hey Prashant,
I am getting the same segementation error (with backtrace) problem with execute_at_end UDF. Did you get any solution to this? Thanks Mayank |
March 11, 2011, 01:26 |
Chao Li
Rep Power: 16 |
Hi kmayank, I got the same problem when I was runing a parallel calculation with a UDF about DPM, can you give any suggestions?
Thanks a lot. lich |
March 14, 2012, 23:12 |
Rep Power: 15 |
From where did you get the formula for critical velocity?
July 10, 2012, 10:39 |
critical velocity of gaseous particle
Rep Power: 15 |
Here is the formula for critical velocity of a particle written in udf form:
real bk_cgs = 1.38e-16; /* cm^2-g/s */ real bk_si = 1.38e-23; /* m^2-kg/s */ lam =(1.3807e-23*P_T(p))/(3*3.141592*C_R(c,cthread)*(1/1000)*C_MU_L(c,cthread)*C_MU_L(c,cthread)*100*Reyo lds) |
Error " stack backtrace " | Arnaud | FLUENT | 2 | May 25, 2011 15:57 |
Segmentation fault No stack | lakeat | OpenFOAM Installation | 0 | December 4, 2007 08:57 |
SEGMENTATION VIOLATION | kROZ | FLUENT | 1 | May 4, 2006 09:12 |
SEGMENTATION VIOLATION | ashish | FLUENT | 0 | April 22, 2006 12:51 |
SEGMENTATION VIOLATION | Arif | FLUENT | 3 | May 27, 2003 08:24 |
