Transient boundary conditions changing type over time
Like Tree1Likes
  • 1 Post By LukeFullard
Old   August 13, 2012, 05:52
Default Transient boundary conditions changing type over time
Luke
LukeFullard is on a distinguished road
Hi, I have a question regarding the setting of boundaries via a UDF.
Suppose at time t0 I set a certain boundary to be a wall. Can I write a UDF which at time t1 changes that boundary to an inlet with a certain flow rate?
My guess is that is possible, however, I have a follow up question which is more difficult.
Suppose I have a closed domain except we have one inlet, the rest of the boundaries are set to walls. Is it possible to have the position of the inlet changing smoothly with time? For example, imagine a box which we are pumping fluid in on the left side, then slowly move the inlet to the right side of the box?
My feeling is this is very difficult, but is it possible in Fluent?
Finally, is this possible in Polyflow?
Thanks for your help
the_ichthyologist likes this.
LukeFullard is offline   Reply With Quote
boundary condition, fluent, udf
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
LES in DES can't be actived! shenying0710 CFX 17 January 23, 2014 04:45
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
