Assigning Temperature at wall boundary
Old   August 13, 2012, 00:26
Default Assigning Temperature at wall boundary
Syavash Asgari
syavash is on a distinguished road
Hi Guys,
Does anybody know how to assign specific temperatures to wall boundary faces at each time step? The temperature value at each face is distinct and doesn't obey any particular instructions. So I don't think can make this by Define_Profie.
Any Idea? I really need to know wether it's possible.
tnx.
syavash is offline   Reply With Quote
Old   August 13, 2012, 02:40
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
What do you mean "doesn't obey any particular instruction"?
If you don't have any rule to set the value of the temperature, then there is no need to set up a simulation
If you have any specific rule, this can be done with Define_Profile, even for time-dependent simulations.
flotus1 is offline   Reply With Quote
Old   August 13, 2012, 09:39
Syavash Asgari
Hi flotus,
Tnx for replying.
Actually temperature for each face is obtaind by exerting an inner loop, depending on someparameters like htc etc. Thus temperature for each node is changing at every time step. What do you think? Is there Any solution possible for this case?
Tnx for caring about this issue.
Old   August 13, 2012, 11:06
flotus1's Avatar
Alex
The implementation with a UDF should be straightforward.
Could you be a bit more specific about the way the temperatures are to be calculated?
Old   August 13, 2012, 14:19
Syavash Asgari
Tnx for your response.
Assume a wall boundary that has a temperature distribution T. At each face or node, temperature should be calculated within a loop at each time step. The procedure of calculating temperature is implicit and it depends mostly on convective heat transfer coeff. of the same face. After obtaining temperature of all faces, we should apply it to wall boundary and this process continues until desired time reached.
Assigning constant temperature to an interface boundary in a conjugate HT. fshak92 STAR-CCM+ 3 February 16, 2012 07:36
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
Free Stream Temperature wall boundary condition emanuele FLUENT 0 March 19, 2007 10:45
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 01:41
