udf code for anisotropy turbulence model- square duct
Old   February 28, 2012, 18:18
Default udf code for anisotropy turbulence model- square duct
Eli_Ja
Eliasjal is on a distinguished road
Hi everybody,
I'm trying to simulate a fully developed flow in square duct to predicate the secondary flow motion.
I already obtained this kind of motion using RNG model but i have to compare with the anisotropy turbulence model or so called (nonlinear model)
since its not available in fluent so i need to use UDF , so do you guys have the udf code so i use it ???
thank you much for help
Eliasjal is offline   Reply With Quote
Old   August 29, 2012, 10:26
hava
shmhava is on a distinguished road
Hello Eli,
Could you please tell me how you achieved secondary flows with RNG, because I tried RNG with enhanced wall treatment with all its options in fluent, with no success. Did you use udf or the simulation was transient?
Thank you,
Hava
shmhava is offline   Reply With Quote
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 11:50
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 10:48
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
