March 22, 2011, 10:29 |
Accessing profile data from a UDF
Robert
Rep Power: 16 |
Hello...
I need to access a data from a transient profile file to use in my UDF. I have time varying angle value (e.g. profile_name theta). Has anyone programmed a UDF to perform this task?... from UDF: I need to say angle = ??? <-- needs to be equated to (profile_name theta) at current time as theta is a time varying quantity. Please post a solution if you have one. Thanks... |
October 14, 2015, 09:21 |
Rep Power: 15 |
Dear all,
I have the same problem at the moment: I want to access the data of a normal velocity pattern/profile of the type ((velocity transient xx 1) (time ) (vel ) ) via an UDF, since I want to create a parabolic velocity profile at the inlet which needs to use the maximal velocity at each time step. Does anybody have any idea? Thank you in advance! Lilly |
transient profile |
defining temperature profile with UDF | mohammadkm | Fluent UDF and Scheme Programming | 11 | July 3, 2013 00:15 |
Help please! UDF for Temperature profile in 3D | subhankar_bhandari | Fluent UDF and Scheme Programming | 2 | August 16, 2010 08:37 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
CFXSolver Error Message using Profile Data on B | Tobias | CFX | 0 | August 26, 2005 07:27 |
Accessing solution data in UDF | Ale | FLUENT | 1 | June 12, 2002 00:25 |
