Parallel UDF for viscous resistance for porous media
Old   March 9, 2013, 14:31
Default Parallel UDF for viscous resistance for porous media
CfdMirco is on a distinguished road
I'm having problem with a parallel udf for viscous resistance for porous media.
During the compiling process, when i load the udf, fluent give me this error: Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
I do not understand what I'm doing wrong, someone can help me?
Thank you!!
Here is the code:
#include "udf.h"
#include "mem.h"
#include "unsteady.h"
#include "metric.h"
DEFINE_PROFILE(vres_pro10,thread,nv)
cell_t c;
#if !RP_HOST
real time=RP_Get_Real("flow-time");
begin_c_loop(c,thread)
C_PROFILE(c,thread,nv)=-(0.6632*exp(-1*((time+4-4.216)/0.3303)*((time+4-4.216)/0.3303))+2.384*exp(-1*((time+4-3.812)/0.6343)*((time+4-3.812)/0.6343))+0.02211*exp(-1*((time+4-7.055)/0.3902)*((time+4-7.055)/0.3902))+1.062*exp(-1*((time+4-6.428)/1.673)*((time+4-6.428)/1.673))+(-4.059)*exp(-1*((time+4-440)/2032)*((time+4-440)/2032))+(-0.02729)*exp(-1*((time+4-8.068)/0.01501)*((time+4-8.068)/0.01501))+0.5449*exp(-1*((time+4-8.327)/2.103)*((time+4-8.327)/2.103))+3.839*exp(-1*((time+4-12.16)/7.86)*((time+4-12.16)/7.86)))*(((3.14*(6.25*(10e-6)))/4)/(7.12*10e-5));
end_c_loop(f,thread)
#endif
CfdMirco is offline   Reply With Quote
Old   March 15, 2013, 08:49
Paritosh Vasava
vasava will become famous soon enough
Can you compile your UDF for serial process?
If yes: Your UDF need modification in order to make it 'compilable' for parallel process.
If No: Your compiler is not set right.
vasava is offline   Reply With Quote
parallel, porous media, udf, viscous resistance
viscous resistance coefficients in Porous media choyong FLUENT 9 December 15, 2014 20:01
Problem in using UDF in parallel computing Yogini Fluent UDF and Scheme Programming 0 January 22, 2013 08:23
UDF Error with Parallel affter several step trantoan2008 Fluent UDF and Scheme Programming 0 January 7, 2013 07:33
UDF for viscous resistance for porous media with time variable benson621 Fluent UDF and Scheme Programming 2 November 24, 2011 11:59
UDF in parallel analysis? Ricky FLUENT 0 May 5, 2003 04:44
